47 Lightning Heads To Rf Powerboats >
Old 08-29-2011 | 08:15 PM
Default 47 Lightning Heads To Rf Powerboats
I Am In The Process Of Towing My 47 Lightning To Washington, Nc To Rf Powerboats. Had A Wet Transom And Then Discovered That Half Of My Stringers Were Hollow, So Needless To Say I Lost The Whole Summer Of Boating, Which Is A Whole 3 Months In The Boston Area. Planning On Redoing My Stringers And Raising My Drives About 2 Inches. Prop Shaft Height Right Now Is 2 Inches Below The Running Surface Of The Hull. Power Is Triple 800 Sc With Imco Minus 3 Drives, 1:50 Gear Ratio, 31 Pitch 6 Blade Hering Props, Speed Is 101 Mph At 5900. I Am Wondering How My Props And Drives Are Going To Hold Up Running 2 Inches Higher Than Present. The Water Line Right Now Is Just Over The Prop Hub At
70+. I Am Concerned About Not Having Enough Cooling For The Drives And Snapping Prop Shafts. Has Anyone Experienced Anything Similiar That Can Help Me With My Project?
47 lightning is offline
Old 08-30-2011 | 03:43 PM
Look forward to seeing you tomorrow.
Reggie Fountain is offline
Old 08-30-2011 | 04:35 PM
take some before and after pictures !
TooTall is offline
Old 08-30-2011 | 05:29 PM
TRL505's Avatar
47 Lightning,
Looks like we may run into each other @ RF. We are flying out tomorrow.
I would trust RF's suggestions and opinions on how to run your setup. They have been very thorough with us...I say this before we have run the boat...but so far everything has come together in nice fashion. I hope you have the same experience as we had.
TRL505 is offline
Old 08-30-2011 | 07:44 PM
I hear of alot of rot problems on 47s wonder why
flat rate is offline
Old 09-01-2011 | 09:43 AM
Hey Reggie, Just got back at 3am this morning. It was nice meeting you and all of your staff. It feels good to know that my boat is in good hands. Keep in touch.
Old 09-07-2011 | 09:39 PM
We are getting it stripped now. Should finish the derig tomorrow & the glass work will start Friday.
Old 09-09-2011 | 02:28 PM
Hey Reggie..I found some fiberglass hatch inserts that measure 14 1/2 wide X 19 1/2 long and 3 1/2 inches tall..if you could measure my hatch and cushion thickness to see if this 3 1/2 inch will fit under the cushion..
Old 10-05-2011 | 04:42 PM
Here are some pictures of the project on my 47 that RF Powerboats is doing.
Attached Thumbnails 47 Lightning Heads To Rf Powerboats-fountain4new.jpg   47 Lightning Heads To Rf Powerboats-fountain1new.jpg   47 Lightning Heads To Rf Powerboats-fountain2new.jpg
47 Lightning Heads To Rf Powerboats-fountain20new.jpg   47 Lightning Heads To Rf Powerboats-fountain12new.jpg
Old 10-05-2011 | 04:45 PM
Some more Pics....
Attached Thumbnails 47 Lightning Heads To Rf Powerboats-fountain17new.jpg   47 Lightning Heads To Rf Powerboats-fountain25new.jpg   47 Lightning Heads To Rf Powerboats-fountain26new.jpg
47 Lightning Heads To Rf Powerboats-fountain30new.jpg   47 Lightning Heads To Rf Powerboats-fountain23new.jpg
