Help with cam and head gaskets >
Old 09-14-2011 | 08:52 PM
Artate78's Avatar
Default Help with cam and head gaskets
I have 454mark 4
3964290 heads Cc 100.9
9to 1 cr
333841 intake
800 Holley dp
1.7 roller rockers
Stock manifolds Gil risers wet through hull
Was wondering whats best head gaskets cometic or felpro marine?
Whats a good cam to go with this set up?
Thank. Aaron
Artate78 is offline
Old 09-15-2011 | 07:26 PM
if you have any power adder go with cometics or simlaiar style u have to have a fairly fine finish on your block deck and head for them or chance of water leaking if no power adder any old headgasket would be fine..
jason y is offline
Old 09-21-2011 | 01:38 PM
Are those heads stock? A lot of guys say their all done by 4500rpms. I used a 454HO cam in my set up. Picked up about 6mph but also had the heads flowed.
Itsallgood995 is offline
Old 09-21-2011 | 01:44 PM
Artate78's Avatar
They have 219/188 valves. What heads or you running
Artate78 is offline
Old 09-21-2011 | 04:11 PM
Oh, my mistake I thought that was the L29 casting. I'm running the 279 Vortecs.
Old 09-21-2011 | 09:47 PM
Originally Posted by Artate78
I have 454mark 4
9to 1 cr
333841 intake
800 Holley dp
1.7 roller rockers
Thank. Aaron
i use the felpro marine on 99 percent of the engines i do,no failures, as far as a cam,i sugest a hyd roller.
mike tkach is offline
