Closed cooling systems
Old 09-24-2011 | 09:47 PM
airshares's Avatar
Default Closed cooling systems
Im thinking of adding closed cooling system to a boat Im buying. I operate in the salt water 100% of the time.
Does anyone have experience with these and are they worth the money?
The engines I want to put them on are the Mercruiser 350 Mags.
airshares is offline
Old 09-25-2011 | 03:28 PM
yes, in salt water a great idea...saves the engine and manifolds...
ezstriper is offline
Old 09-25-2011 | 04:57 PM
BUP
Give a call to Mr.Cool they advertise up here and can answer all your questions plus have good prices.
BUP is offline
Old 09-25-2011 | 09:49 PM
airshares's Avatar
Default Thanks!
Thanks for the help guys. I will look up Mr. Cool.
Old 09-26-2011 | 11:16 AM
KEPP's Avatar
Only the Best Will Do!
Default closed cooling
Here's an option as well http://www.keitheickert.com/p-14010-...o-360-cid.aspx
KEPP is offline
Old 10-03-2011 | 12:24 PM
airshares's Avatar
Default @ Kepp
With the EconoCool system I still use sea water to cool the manifolds? With the closed water system how do I do flush the manifolds?
Old 10-03-2011 | 12:44 PM
CIG3's Avatar
The KEPP ststem would take the water from the heat exchanger and run it thru the exhaust manifolds and out.
A fully closed system would also run antifreeze thru the manifolds.
CIG3 is offline
Old 10-03-2011 | 01:47 PM
How do you think you cool your engine??
* Think for chrissakes...
MikeyFIN is offline
Old 10-03-2011 | 02:03 PM
There is no need to be an a$$...
ozarkdevil is offline
Old 10-03-2011 | 02:51 PM
Well I rather be an ass and make him think before some else is an A$$ and takes his money for a simple flush. This is a No-brainer.
MikeyFIN is offline
