383 mag in a V 260 >
383 mag in a V 260
383 mag in a V 260
Old 09-26-2011 | 09:49 AM
Default 383 mag in a V 260
Opinions needed. I was wondering how a 383 mag 350hp will run in a V 260. Verses the 8.2' mag. Looking to repower my 260 again.
qaberdeen is offline
Old 09-26-2011 | 03:36 PM
The 8.2 has 375hp if I am not mistaken, whicg is only 25hp more than the 350hp on the small block you a asking about. I would think the torque is where you would be at a major disadvantage. THe big block is going to give you the torque necessary to turn a 26p 4 blade prop, whicg will push the 260 to high 60's - low 70s. I highly doubt the small block will spin that prop. Plus a small block just doesn't sound as good either.....
low_psi is offline
Old 09-26-2011 | 06:05 PM
low psi, thanks for the input, i was thinking the same thing..is just that i boat with my family alot and want something abit more reliable....
Q
Old 09-26-2011 | 11:55 PM
My 496 mag has been rock solid. Since I bought the boat 2 seasons ago we have put around 400 hours on it with only 3 small issues. I had an alternator fail (my fault), the IAC valve needed to be replaced, and the water pressure sensor went bad. It has been the most reliable and efficent motor I have ever had. Fuel Mileage is incredible. We normally run the boat @ 3800-4200 rpm.
I would think putting a small block where a big block belongs, would only reduce reliability.....
low_psi is offline
Old 09-27-2011 | 07:10 AM
thks again,
i purchased the boat with a 7.4l mpi, had reversion issues after a season or so, went to 560hp carb engine which has been nothing but trouble...motor runs good, but the idling characteristics i cant handle..it loads up fast and bogs down when i'm idling at low rpms, which makes docking, rafts ups in tight quarters almost imposible..so i'm thinking that i want to go back to the stock engine for those factors.. i olny have 40hrs on the motor and i'm ready to change it..also i don't have any marine mechanics that understand these types of motors to tune it properly..
but thanks again for the input..
Q
Here's a pic my engine
Old 09-27-2011 | 12:37 PM
If I were you I would look for a use low hour 496mag or 496mag ho.
low_psi is offline
Old 09-27-2011 | 05:41 PM
stick the old school lesson. there is no replacement for displacement.
Vicious22 is offline
Old 09-27-2011 | 08:24 PM
Don't know about the 496 but my 1998 502 mag EFI has been absolutely reliable. Turn the key and go. Only engine problem was with the power steering pulley. Cheap peice of plastic sh*t I would go with the cubic inches,
Padraig is offline
Old 09-27-2011 | 08:37 PM
I would keep what you have and continue to look for someone , to tune it right.
Revd Up is offline
Old 09-28-2011 | 07:12 AM
thks guys, actually i'm working on that now, to have someone tune it...so hopefully all goes well..
