Bravo Gear Lube >
Bravo Gear Lube
Bravo Gear Lube
Old 10-01-2011 | 07:24 AM
Default Bravo Gear Lube
I know alot of guys have switched from the Merc Hi Perf gear lube to synthetic 75-90 ..
Is automotive Synthetic 75-90 GL-5 good for the Bravos?any issues?
Im thinking been Synthetic will be better than the merc lube..
boatnt is offline
Old 10-01-2011 | 07:46 AM
Smitty's Avatar
Be careful... it isn't just about changing to a synthetic...
You need to choose something that also has additives in it that can handle high levels of moisture. Most automotive lubes do not. Make sure it says "marine use" on it. If it does not well then get ready for drive issues down the road.
Smitty is offline
Old 10-01-2011 | 07:50 AM
well the reason I ask is I read alot of people using Mobil 1..thats a automotive gear lube..
thanks..maybe Il see you at the river shiver.
boatnt is offline
Old 10-01-2011 | 08:53 AM
Default Try This Product
IMO, this is the best!!
http://www.amsoil.com/storefront/agm.aspx
Mariah212Z is offline
Old 10-01-2011 | 09:00 AM
Originally Posted by Mariah212Z
Thanks..
But right now Im not looking for brand,,Im wondering if Automotive Synthetic 75-90 GL-5 is ok to use in a Bravo..
I think alot of guys on here use it..any issues?
boatnt is offline
Old 10-01-2011 | 09:06 AM
Default My Experience
Thanks..
I have used it since I bought my Mariah in 1995. This was with the stock 350 mag for 10 years to my current 350HP Vortec motor for the last 6 years. I have not had one issue with my Alpha One.
Old 10-01-2011 | 09:51 AM
Thanks..
There's is nothing wrong with using a, as you say it, an automotive gear oil. A GL-5, however, does have more sulphur in it, an extreme pressure additive, but sulphur can have an adverse effect on soft yellow metals if it gets too hot, which are sometimes found in marine lower units. Also, a regular gear oil will not have a water emulsifier built into, such as the above mentioned AMSOIL Marine Gear Oil does. That product is able to handle 10% water pollution, without having an effect on it.
07DominatorSS is offline
Old 10-01-2011 | 03:04 PM
I switch every bravo I have to royal purple..I consider merc lube trash...after a few years sitting the stuff turns to sludge in the bottle and the in res in the boat....some have had that clog, destroy the drive as looks like you are fine !!! no issues switching...
ezstriper is offline
Old 10-01-2011 | 03:16 PM
articfriends's Avatar
I spent alot of time and thousands testing outdrive lower gears trying to get them to live longer, experimented with heat treating, cry/iso rem, dlc coating, back lash, you name it. I used Royal purple the whole time convinced it was great stuff, when I finally started using something BETTER I doubled the life of my gears over everything else I ever tried, I NOW consider Royal purple gear oil garbage and would never run it in a Bravo again behind BIG power. FWIW based on my personal experience, Smitty
I now use NEO from the bravo shop (haven't ran it long enough to form a opinion) and I did have good gear life with Amsoil Severe gear with 10-20% lucas oil stabilizer
articfriends is offline
Old 10-01-2011 | 06:18 PM
carter38's Avatar
+1
carter38 is offline
