What is Causing This? >
Old 11-07-2011 | 01:16 PM
Default What is Causing This?
I just put her to bed yesterday and came across this. It only has about 5 or 6 hours on it since the re-build. It is a 496 with Dart heads and CMI sport tubes.
Is there more to this rust than just rust or is it nothing to worry about?
Thanks for the help.
Attached Thumbnails What is Causing This?-dscn0487.jpg   What is Causing This?-dscn0490.jpg   What is Causing This?-dscn0492.jpg
TW720HVY is offline
Old 11-07-2011 | 01:35 PM
Knot 4 Me's Avatar
Looks to me like heat has just burned the paint away and then normal condensation has caused some minor surface rust.
Knot 4 Me is offline
Old 11-07-2011 | 02:03 PM
might be some water running up the head bolt,i dont know what block you are useing,but if the headbolt holes are not blind holes,you need a lot of sealer on the threads or that will happen,pull that headbolt ,clean it,and apply locktite PIPE THREAD SEALEMT.
mike tkach is offline
Old 11-07-2011 | 03:29 PM
Thanks for the replies. I did not know if I was over thinking this.
mike tkach, it is the stock 496 block.
TW720HVY is offline
Old 11-07-2011 | 05:06 PM
If it is closed cooling it would be antifreeze leaking around the head bolt not water. You could pressure check the cooling system but if it is not low I would not worry about leaking head bolts .
Jeff P31 is offline
Old 11-08-2011 | 09:44 AM
It is a closed cooling system.
Can reversion cause this?
TW720HVY is offline
Old 11-08-2011 | 10:39 AM
Knot 4 Me's Avatar
You would have an exhaust leak then that would be quite noticeable.
Old 11-08-2011 | 06:41 PM
Thank you everyone for the help!
TW720HVY is offline
