700 Top End rebuild questions >
Old 11-15-2011 | 08:10 AM
Default 700 Top End rebuild questions
Looking for some true experiance with what I should/need to do with my 700's. I just found out that I have to do the top ends on my motors cause I have 220 hrs. Being told that there is a must 250 top end per mercury. Any thoughts/experiance/help... thanks
Mykalvballer is offline
Old 11-15-2011 | 08:24 AM
Knot 4 Me's Avatar
Give Eddie Young a call.
Knot 4 Me is offline
Old 11-15-2011 | 12:41 PM
HAVE 305 HRS ON 700'S JUST DID LEAK DOWN NO ISSUES NEVER HEARD THAT THERE IS A MUST 250HR TOP END PER MERCURY-- HAD NXT DRIVES REBUILT AT 265HRS BUT SO FAR NO ISSUES WITH MOTORS
robert246 is offline
Old 11-15-2011 | 02:43 PM
I think Merc., recomends after 400 hrs., top end depending on driver.
JMPH is offline
Old 11-16-2011 | 01:18 AM
There is no rebuild or top end refresh schedule from Merc for the 700sci that I am aware of.
If leak down tests are good, then I'd probably just do valve springs to be on the safe side.
Griff is offline
Old 11-16-2011 | 10:02 AM
cdowns's Avatar
Commercial Member
And Rocker arms.
cdowns is offline
Old 11-16-2011 | 11:41 AM
I think the most important is replacing the roller lifters,rocker arms are usualy okay, valves touched up depending on condition to replace or not,valve springs and head gaskets.IMO But I thought you could go 400 hrs depending how hard your on it.
Joe
JMPH is offline
Old 11-16-2011 | 11:46 AM
BrettM's Avatar
Offshoreonly Advertiser
Commercial Members
We just upgraded a set with new Cometic head gaskets, upgraded springs and Crowler rocker arms. Found several weak springs and bad rocker arms. 200hrs on motors.
BrettM is offline
Old 11-16-2011 | 12:07 PM
525's need springs and rockers (maybe) at 250 hours and 700's don't?
Does the blower allow that much smaller of a cam?
Wildman_grafix is offline
Old 11-16-2011 | 06:25 PM
Originally Posted by nebraskabaja
We just upgraded a set with new Cosmetic head gaskets, upgraded springs and Crowler rocker arms. Found several weak springs and bad rocker arms. 200hrs on motors.
did you change the lifters? just curios.
Joe
JMPH is offline
