Thrust washer for Hydro prop on XR shaft >
Old 06-16-2002 | 10:26 AM
kook
Default Thrust washer for Hydro prop on XR shaft
Getting through to Hydromotive has been futile - always busy.
Got a Hydro Q-IV with the solid "fat boy" (XR) hub. I was told that the Hydros do not use the same thrust washer as the Bravo1 prop. Below is a scan-in of what Hydromotive sent me with the prop.
Don at Triad Performance Marine (www.tpmarine.com) sent me a kit - the kit appears to be identical to the parts list that Hydromotive sent me............ But the kit is a product of Mercury Marine.
What's the real deal here? First, there is no washer that goes in front of the prop - just 3 washers and the nut. The first washer to go on after putting the prop on the shaft is a thick 1.5" washer.
Attached Thumbnails Thrust washer for Hydro prop on XR shaft-propwashernutdetails.jpg
Old 06-17-2002 | 12:09 AM
SteveDavid's Avatar
Charter Member #1093
Kook,
They both use the same washer set up. The first is a fatter one , the second is a "belleville" washer (convex in shape) and the last washer which is the one the lock nut goes against, is a flat SS washer.
Have fun,
Steve
SteveDavid is offline
THRILLSEEKER
Prop Talk
2
05-27-2008 07:20 AM
BajaRunner
13
07-18-2006 09:01 AM
onesickpantera
Prop Talk
4
05-19-2006 07:53 AM
1BIGJIM
1
05-08-2006 12:34 PM
duunoit
2
06-06-2003 01:36 PM
