Whipple Upgrade for 525efi >
Old 01-14-2012 | 08:28 AM
Default Whipple Upgrade for 525efi
Does anyone have any feedback on this?
I'm talking about the computer recalibration, not the super charger. Sounds great to me and not very costly. I think I would need to run 91 octane if I choose to do this.
http://www.whipplesuperchargers.com/...sp?ProdID=1283
raytart is offline
Old 01-14-2012 | 08:42 AM
obnoxus's Avatar
Charter Member #1171
reread his post !!!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 01-14-2012 | 09:09 AM
There's a guy up in Bolton Landing on Lake George that's pretty good with Whipples, EFI, etc. He programed 2 engines for me and they came out perfect.
Rattlesnake Jake is offline
Old 01-14-2012 | 09:49 AM
Did any other work need to be done like Razor states?
Or Just plug and go?
raytart is offline
Old 01-14-2012 | 10:46 AM
I kicked this around on a Donzi forum since it is tempting with the Whipple price drop. I was advised to have the ECU calibrated on a dyno and then again on the water. I also think that the lumpy 525 cam would not be a good choice for a SC engine and the compression should ideally be lowered too. I decided to wait.
thirdchildhood is offline
Old 01-14-2012 | 10:56 AM
I actually read your post/question,and think it looks like a great product!
Upgrading props will prob help to achieve optimal results.
Keep us updated on how it turns out!
offshorexcursion is offline
Old 01-14-2012 | 11:11 AM
I already purchased New Prop. I intend to recal the pcm, but will not be able to run the boat till spring. I have a very reputable local guy that suggested I bump the rev limiter up to 5800 (he does not reccommend 6000 rpm because of the XR weak link). He has a guy to do this, but I'm not sure what he intends to do. I need to talk to him to see if the recal is only for the rev limiter or other stuff like Whipple would do. I will keep you posted.
Please keep the feedback coming
PS: This is ONLY a PCM upgrade and NOT a blower stage 1 kit.
Ray
raytart is offline
Old 01-14-2012 | 11:17 AM
Ok I'm an !diot, I read the op got it as a question regarding the calibration of an sc setup. Have no exparience with the ecu upgrades other than on 496's. Works fine, but not a lot of top end improvement. Don't know if the same will be the case on the 525EFI. On the 496's a thermostat change is needed.
A.O. Razor is offline
Old 01-14-2012 | 11:52 AM
lol I made the same mistake of assuming the thread was about a Whipplecharger! Ooops...
Old 01-14-2012 | 11:59 AM
obnoxus's Avatar
Actually I would try running the same prop as well.
That reprogram raises the rev limter as well to help use the entire power band of the engine.
obnoxus is offline
