Prop integrity-metallurgy >
Old 01-26-2012 | 12:30 PM
Question Prop integrity-metallurgy
Recently purchased a used prop, specifically a 24p Bravo 1.
Upon receiving and inspecting, I noticed some significant pitting and corrosion on 2 of the vanes in the inside. Otherwise the prop looks like new, and the rest of the interior casting looks excellent. But I also noticed you can see a small indented seam extending from the top and the bottom of the blades on the outside of the prop, to the top and bottom of the outside of the prop.
I've had a few other Mercury props and I've never noticed either one of these issues. A small amount of the pitting actually goes clear through to the hollow part of the casting.
Ya'll think I should be concerned? Bad casting? Factory reject maybe? Rebuilt from catastrophe?
Like I said, without close inspection, you'd never notice these imperfections, but before I put it to test, I'd like opinions on the integrity of this prop. Single engine application less than 400hp, low hour freshwater use. Thanks.
bigbang is offline
Old 01-28-2012 | 08:38 AM
pictures???
pstorti is offline
Old 01-28-2012 | 08:56 AM
Biggus's Avatar
It's typical. Merc props are hideous. On the other hand, I've yet to see a failure as a direct result of the porous casting.
Biggus is offline
