What if trim pump goes out in the water?
I am new to boating and wanted to be prepared. I was thinking the other day what if the trim pum goes out in the water? Is there a way to manually "trailer" the out drive to get the boat loaded?
Bravo 1 fyi
Bravo 1 fyi
I have seen the lines disconnected and manually lift the outdrive and tie it up. However, there are a million "what-ifs" in boating. You may be overthinking, regular maintenance along with general preparedness goes a long way. Relax and enjoy boating!
I had mine fail on me last year. The drive was in the Trailer position out at the sand bar, and wouldn't lower.
I ended up swapping the hydraulic lines around so I could lower it, headed back to the dock, swapped them again to raise it. It was a pain, but it kept me on the water, and I made it home no problem.
-Rob
-Rob
Check to see if you've got power to the pump first. If you've got power but the switch is inop; they are easy to jump. Pull the little black cover off where the power/ground strip is on the pump. Blk is ground, blue is up, green is down. If the drive is stuck in the down position, take a screwdriver and jump the black to the blue and it will raise if there is power. Blk to green to lower.
Hope this helps.
Kurt
Hope this helps.
Kurt
