Here's the New 502! Looking for 625HP >
Old 03-28-2012 | 07:21 PM
Default Here's the New 502! Looking for 625HP
Here's my story!
Bought it july 1st! 35hrs since rebuild.
Sat for 3 years, the guy is still sitting in jail.
Ran my 27 Fountain last summer, No problems.
Wanted a little more speed, as we all do.
Started the engine this year for the 1st time March 10th, March 12th, pulled the engine.
Wanted to find out what cam was in it, overall I needed to know what was in the engine, bored? broken? stock? good or bad?
Broke the engine down, found that the mild cam was too much for the stock exhuast. lite water damage to the valves.
So, didnt want to pour $$ into stock heads. Call Bob @ Marine Kinetics. Started talking about Heads and Cams.
March 14th Ordered AFR 290 Oval Heads, Custom Cam from Bob.
Next, with 290 heads, needed headers. Found a set of used 500 efi headers made by CMI, and used set of tails on Ebay.
The stock Mag /MPI was the next mountain to climb.
Called Alex with Haxby Marine, ordered the Holley HP EFI TBI system, Victor Jr Intake.
Today 16 days later, The motor will be installed Thursday around noon, Hope to have it in the water saturday for a Poker Run in Orange Beach, AL.
Big thanks to Bob & Alex for all of there help!!!
YellowFever is offline
Old 03-28-2012 | 07:34 PM
Default pics
Pics
Attached Thumbnails Here's the New 502! Looking for 625HP-iphone-pics-218.jpg   Here's the New 502! Looking for 625HP-iphone-pics-217.jpg   Here's the New 502! Looking for 625HP-iphone-pics-224.jpg
Here's the New 502! Looking for 625HP-iphone-pics-212.jpg   Here's the New 502! Looking for 625HP-iphone-pics-122.jpg
Old 03-28-2012 | 08:21 PM
Holy crap, u dnt f&@k around!! That's fast!! Bob is great and u will love the new found power!!
rivermonkey is offline
Old 03-28-2012 | 09:26 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
YellowFever , I also talked with Bob Madara about doing something very similar with my HP 500 . I would be very interested in your results . Do you plan on getting your engine dynoed ?? I personally am at a crossroad and am thinking on just building a 540 because the HP probably will need freshened soon . Anyway , i want to hear all about your engine and the components you used . By the way Bob is quite the gent and a real pleasure to work with as you already know . Thanks
the deep is offline
Old 03-28-2012 | 09:30 PM
Bob, ordered the heads on the 14th, they shipped 4 days later. Super fast!! Fully ported, Bad B!tches for sure. The Holley EFI is a self tuning, with a O2 sensor. Put the HP EFI Unit in learn mode and BAM! Fully tuned!
Heres the old #'s
66.4 mph at 4700 ish rpms
w/ Ron Hill Custom 5 Blade LH 25*
Old 03-28-2012 | 09:43 PM
The engine was rebuilt in 2008, 35 hrs were put on the new engine. Then the owner went to jail, I bought it RIGHT, from his dad. So I didnt know much about the rebuild, the repairs sheets showed 3300.00 for rebuild Short block. The block is stoke bore, looks new compared to the age on the heads.
I didnt break down the short block. Motor was running, so no metal debris or trash.
Gen 6 Block
4340 Crank
SRP Pistons 75F
AFR 290 Oval Port Heads
100% CNC Ported Exhaust Ports
100% CNC Ported Intake Ports
100% CNC Ported Combustion Chambers
Competition 5-angle Valve Job
Isky Springs
Comp Cam Lifters
Comp Cam Mag Series Rockers 1.7
Manley Push Rods
Bob Madara Cam
Ill Post some Engine Pics Thursday Night.
BC
Old 03-28-2012 | 09:47 PM
the deep's Avatar
Fast Singles Club
Gen 6 Block
4340 Crank
SRP Pistons 75F
Isky Springs
Comp Cam Lifters
Manley Push Rods
Bob Madara Cam
BC
NICE , thank you my friend .
the deep is offline
Old 03-28-2012 | 11:15 PM
I was LOOKING for 625hp out of my new 540 too, but i came up about 60hp short. I think your hp # is a bit optimistic, but I think you will be happy with the results. It should pick up ALOT. Nice time frame. I think it took longer than that for me to get my cam from Bob. Good luck on your project.
snapmorgan is offline
Old 03-28-2012 | 11:24 PM
snapmorgan
What heads did you have?
Old 03-28-2012 | 11:29 PM
I would do plug checks and verify what a/f meter is doing. On a boat you tend to get some crappy reading and tend not to be as accurate as you would like. Unless of course your tails are dry. You can't get the 02 to be in the right place and not get wet.
GTOFFSHORE is offline
