Oil temp
Old 04-02-2012 | 09:28 AM
Artate78's Avatar
Default Oil temp
I have a 468 N/A With crossover and hose running from crossover to tstat housing 160* tstat .have my oil Temp sender in the extra pipe threaded hole on remote oil filter. What temp should I be seeing? Just cruising around 3000 RPM I am seeing 225* new motor first time out yesterday. I have the cooler bypassed because with cooler hooked up running on water hose was only seeing 100* oil temp. Never ran it in the water with cooler hooked up so can't give you that temp.
Artate78 is offline
Old 04-02-2012 | 08:44 PM
I would at least give it a shot hooked up to the cooler actually in the water. Producing a load on the engine may make the oil temps rise above that 100 degree mark like when you were on the hose. Plus if you are like me, I only run idle/high idle on the hose. I can suck a garden hose flat if i rev it once. so i just dont. The lack of load on the engine and the low running on the hose could be why your temps never rise. I run a thermostatically controlled cooler. My oil temps hover around 190 and can touch the 200s. Perhaps you need a thermostat..
Fixxxer22 is offline
Old 04-02-2012 | 08:54 PM
X2 Hook up the cooler and try it under load . You will not get much heat in the oil just running it on a hose.
Jeff P31 is offline
Old 04-02-2012 | 09:34 PM
1980Condor460's Avatar
Hey 78 - did you pick up your 923 from Damon?
1980Condor460 is offline
Old 04-02-2012 | 10:28 PM
Artate78's Avatar
No he sold it to some punk in hot springs.he had it for a few weeks blowed up the motor patched it back together and then ripped me off. But yes it was Damon's. I have talked to damon a few times. He has been very help full. Do you know him?
Artate78 is offline
Old 04-02-2012 | 10:34 PM
Artate78's Avatar
Ok what oil temp is to high? And what is to low?
Artate78 is offline
Old 04-02-2012 | 10:58 PM
Fenderjack's Avatar
Pirate of the Chesapeake
225 is not bad bad, but would seem to be getting close for some. 220 is where we try to keep it, don't let it get to cold, as it will foam up. So IMO and alot of others 220 is about the mark
John jr
Fenderjack is offline
Old 04-03-2012 | 01:46 AM
260* = be careful and keep a close eye on it
280* = way too hot and the oil will start breaking down
The oil should get to at least 210* cruising in the 3000-4000 rpm range to burn off condensation.
Griff is online now
Old 04-03-2012 | 08:13 AM
The Mercury Racing 525 service manual says max oil temperature is 220*F. Hook up your cooler.........
thirdchildhood is offline
