running circulation pump w/o water >
Old 04-04-2012 | 10:32 AM
Default running circulation pump w/o water
3 times last season i got junk in my water intake and got motor up to to buzzer temp.
I replaced the seawater pump, but didnt know what effect this would have on the circ pump..
How long can the circ pump run dry?
tnc110 is offline
Old 04-04-2012 | 10:51 AM
i think your fine, if your refering to the actual eng water pump on front of the engine there is no rubber parts inside to burn up like inside the raw water pump/impeller...
roughwater is offline
Old 04-04-2012 | 12:05 PM
You still had water in the block so it did not run dry.
It still has a seals.
1BIGJIM is offline
Old 04-04-2012 | 01:14 PM
If the seals run dry for any length of time they will start leaking.
ThisIsLivin is offline
Old 04-05-2012 | 06:13 PM
mcollinstn's Avatar
Yeah, you can burn the seals, and even scorch the snout bearings.
But if you don't have any water leaking out from behind the pulley, you're good.
MC
mcollinstn is offline
Old 04-06-2012 | 12:32 AM
As long as no water is dripping out the weep holes, then it is fine.
Griff is offline
Old 04-06-2012 | 07:34 AM
^^^^^This...
Old 04-06-2012 | 03:50 PM
you would damage more than the circ pump if you got it hot enough and dry enough to do damage to it.
dereknkathy is offline
