My v8 won't start with a v6-14 module >
Old 04-07-2012 | 03:45 PM
Default My v8 won't start with a v6-14 module
Pulled out my v8-24 and swapped in a v6-14. It hit once and tried to start and now it won't do anything but crank. I'm by myself so I haven't been able to check for spark at the coil but im assuming since it hit once there is spark. I've tried pumping and pumping and nothing. Tried holding it wide open and still nothing, any ideas would be great
87MagnumII is offline
Old 04-07-2012 | 03:49 PM
any reason you didn't use the correct module ?
stevesxm is offline
Old 04-07-2012 | 04:03 PM
Need more base timing, but need to keep my total around 32
Old 04-07-2012 | 04:27 PM
try putting the old module back in,if it starts,the v6 module is no good,if it still wont start,something else is wrong.
mike tkach is offline
Old 04-07-2012 | 05:58 PM
Kind of what I'm suspecting, I killed the battery trying to start it, I'm gonna put the v8 module back in tomorrow and see what happens
Old 04-08-2012 | 01:14 AM
Is the module grounded properly????? Both the ground wire and the module case need a good ground or you won't get any spark.
Griff is online now
Old 04-08-2012 | 09:05 AM
Or very weak spark with bad grounding.....
Redhook98 is offline
Old 04-08-2012 | 09:18 AM
This is a correct statement....dont ask me how I know...lol.
tinman565 is offline
Old 04-08-2012 | 09:31 AM
I bolted it in exactly as the other one came out and the boat ran before I changed modules. Im going to try and clean up the surface of the plate and try to get a better ground. I'll post back results later today.
