sealing k-plane indicator cables >
Old 04-09-2012 | 07:46 PM
Default sealing k-plane indicator cables
I removed the k-planes from my boat to repaint the transom plate on each k-plane. I removed the indicator cable pass through fitting that screws into the k-plane transom bracket. When I want to re-install the k-planes with new indicator cables, do I need to put some sort of sealant on the threads of this fitting? I know there is a nut that screws on top of this that compresses a compression ftting around the cable, but I guess I also have to make sure the threaded fitting that screws into the k-plane bracket is also sealed. Just wondering what I should use? Telflon tape?
FBRONCO is offline
Old 04-09-2012 | 10:16 PM
Rookie's Avatar
Can you post a pic of the nut with the compression fitting? I am going to be installing indicators soon and need to see this and maybe where I can get 2.
Rookie is offline
Old 04-10-2012 | 07:45 AM
I use thread sealer. It's a liquid form of teflon tape. I don't care for teflon tape. Personally, I prefer ARP's thread sealer but any will work for what you are doing.
Eddie
Young Performance is offline
Old 04-10-2012 | 09:27 AM
I will try to take a pic tonight and post it.
FBRONCO is offline
Old 04-13-2012 | 06:01 AM
Rookie, here are the pics you asked for.
Attached Thumbnails sealing k-plane indicator cables-100_0489_small.jpg   sealing k-plane indicator cables-100_0490_small.jpg
FBRONCO is offline
Old 04-29-2012 | 09:27 PM
Rookie's Avatar
FBRONCO thanks for the pic.
Anyone know where to buy these fittings??
Rookie is offline
Old 04-29-2012 | 09:55 PM
c_deezy's Avatar
http://www.drillspot.com/products/45...lief_connector
c_deezy is offline
Old 04-29-2012 | 10:12 PM
spazboz's Avatar
Rookie, you can get them from Van's Sport Center right here in GR. The rubber part and plastic are cheap, the stainless part not. I have the part numbers written somewhere so I don't have to go through the "I'm not seeing it on the computer screen here..." speech every time I go in there! Nick
spazboz is offline
