Need help understanding how to remove CD player from the dash of my Baja Hammer >
Old 04-12-2012 | 09:44 PM
I just purchased my '97 Baja Hammer 214 and need suggestions on how to remove the original stereo reciever. Any suggestions would be much appreciated.
Thanks all.
Full_Throttle86 is offline
Old 04-12-2012 | 11:02 PM
If you don't know how to remove it, should you really be installing something different yourself????
Just cut some 4" pieces of a metal coat hanger and stick them in the 4 little holes on the front. It should slide out then. It may also have a brace strap on the back of the head unit that will need to be disconnected.
Griff is offline
Old 04-12-2012 | 11:41 PM
What brand is the stereo
Waveform is offline
Old 04-13-2012 | 06:55 AM
Typically the outer trim ring comes of the head unit, very carefully snaps off by hand. Then a special tool that resembles a stamped sheet-metal "key" with no teeth slides in each side and depresses the tabs that snap the unit into the housing or frame. I had two keys that would go in each side at the same time, pops the unit right out.
You may want to call Crutchfield and get the correct keys/tools for your brand unit. When I sold my last boat, I left the keys taped in a drawer inside the cabin. Did you receive any documentation, owners manual? They may be in there....
frickstyle is offline
