Low oil temps , milky Oil
Old 05-07-2012 | 05:29 PM
Default Low oil temps , milky Oil
Ok heres the deal 97 fountian with carb 454 mags , Took it out yesterday and never got oil temps over 140even after a hard run , just bought this boat last fall and have not checked to see if the thermostats have been removed the boat came from down south so maybe , what temp tstats should this motor have in it ? and do you guys have any ideas ...
speedfreek1 is offline
Old 05-07-2012 | 05:34 PM
140* milky oil,, did you winterize it when you brought it up from down south?
FIXX is offline
Old 05-07-2012 | 05:40 PM
yes both motors where winterized, and i noticed this last year before it was put up for the winter nap.. just now getting aroung to checking this out..
Old 05-07-2012 | 05:59 PM
blue thunder's Avatar
I believe my 454 carb mags used 160* coolant stats. You most likely need to add oil stats.
blue thunder is offline
Old 05-07-2012 | 06:11 PM
would putting in 180 * stats help any? Im thinking if i can raise my motor temps in turn I will raise my oil temps, both motors are running low temps, prob also in the 140 range and a lil lower ...
Old 05-07-2012 | 06:16 PM
You might get 20* with that but your actual temps may be over 180f on the coolant side which is too hot for a boat. I'd try the 160 and go from there.
Old 05-07-2012 | 09:09 PM
Rookie's Avatar
Is your oil milky and foamed up? Or do you just have oil/condensation on you oil caps or breather?
My old merc 420's would have condensation on the caps and breathers if I was in cold Lake Mi and did not run it hard for a while. When I had a head gasket going, then I had milky/water in the oil.
Rookie is offline
Old 05-12-2012 | 06:34 AM
I'd change that oil before I did anything else, then check if thermostats are fitted. 140 should be enough to boil any water out of the oil, so I'd be very concerned about it's condition.
rsparso is offline
Old 05-12-2012 | 11:02 PM
from my understanding you need oil temp to be more around 200 to 210 to boil out water , water in a pan does not boil untill 212 fh ...
