496 iac
Old 05-21-2012 | 12:22 PM
Default 496 iac
My port engine makes a lot of vacume noise at an idle it comes from the hose from the iac on the back of the intake that connects to the throttle body is this normal I only ask because the starboard engine does not make the same sound both engines idle and run perfectlty though
jab052783 is offline
Old 05-21-2012 | 12:54 PM
Plum_Crazy's Avatar
Is the little muffler still there? It's number 5 in this pic.
Plum_Crazy is offline
Old 05-21-2012 | 01:24 PM
Default 496 iac
I am not sure I will check it when I get home from work though
Old 07-31-2012 | 03:23 PM
Default 496 iac
The little muffler is still in place and when I take the hose from the IAC to the throttle body loose near the throttle body there is a lot of vacume pressure on the hose is this normal?
