Help with Power Steering Actuator >
Old 06-18-2012 | 10:14 AM
Default Help with Power Steering Actuator
I have a 1990 bowrider, has a 454ci w/ bravo 1 . my pwr steering actuator is leaking into the bilge pretty badly. I want to replace it but am having trouble locating one ( affordable).
Merc calls for part # 806034A2. I see alot of part #'s 80634A1
for not too much money .
anybody know what the difference is , or what parts will enter change with my app?
NOPUN is offline
Old 06-18-2012 | 03:08 PM
sooo! nobody knows , or , is this like a stupid question?
NOPUN is offline
Old 06-18-2012 | 04:04 PM
Is this a hybrid system with a cable helm back to a power steering actuator? I can't answer your question but I might have what you need. Can you post a pic? You can use photobucket or similar photo host site.
thirdchildhood is offline
Old 06-18-2012 | 05:07 PM
yeah, it a cable system back to an actuator. the actuator has lines connected to it from the pwr steering pump. will try to get a pic up later.
thanks for the reply !!!!
NOPUN is offline
Old 06-18-2012 | 06:53 PM
Search the Swamp Shop. I see them in there all the time.
People converting to full hydrolic have them laying around.
Or post in WANTED section.
1BIGJIM is offline
Old 06-18-2012 | 07:00 PM
I have the whole set-up from my Donzi. It has 3 seasons on it. Helm, cable and actuator. As said, I took it off when I went full hydraulic. I'd sell it pretty cheap. I'll get up pics too.
IDK if the cable is easy to detach from the actuator. This assy should be the right length for your boat though. I don't want much for it. It'll be a swap shop type thing. Say $50 + shipping.
Old 06-19-2012 | 09:38 AM
Thanks TCH ! This is what I've been looking for. My problem is, still, I need to make sure of what other type parts will work in this application. Here is a couple of pics of what I have now. I know it looks kinda ragged, but that is why I want to replace it !!!
NOPUN is offline
Old 06-19-2012 | 10:12 AM
rchevelle71's Avatar
We had to do one on a Baja once, be careful, the older style, and the newer ones have different size fittings, and do not interchange, unless you change the power steering lines along with the actuator, or find some type of fitting adapter.
rchevelle71 is offline
Old 06-22-2012 | 06:12 AM
you have the early style, they are $$$$, replace with the later, much better and cheaper, probably have to change the 2 hoses if yours does not have O-ring style ends, simple change over....
ezstriper is offline
Old 06-22-2012 | 09:29 AM
You must change the hoses. hard to adapt with over the counter fittings from hydro shops. I spent two weeks and 50.00 ordering and buying fittings to rig it. Wound up buying new hoses from merc. $$
looseconnection is offline
