Load vs rpm drop? >
Load vs rpm drop?
Load vs rpm drop?
Old 06-22-2012 | 08:35 AM
Default Load vs rpm drop?
How many rpm do you guys usually lose when running the boat loaded up vs running light?
When my prop slip was way up the boat actually ran faster when heavier, but now that I have that down to 12-13%, I was running with 6 people on board 3 full coolers, gear, clothes, and 3/4 tank of fuel pulled 4600. Max rpm for my motors is 5000-5200
Unlimited jd is offline
Old 06-22-2012 | 09:40 AM
Over Memorial Day weekend I loaded my boat up--10 people, 1/2 tank of gas, tons of gear, 3 coolers..I lost 400-500 rpm.
Powerquest_Baby!! is offline
Old 06-22-2012 | 01:57 PM
Great thanks for the info, hopefully I am at the same
Old 06-23-2012 | 01:34 AM
I only lose about 100rpm at most, but my prop slip increases about 7% across the board.
Philm is offline
Old 06-25-2012 | 06:25 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
There are so many variables it is difficult to offer a exact answer.
It is true higher slip numbers caused by exagerated X dimentions can be decreased by adding weight. However, speed doesn't always increase. It worked however, in your situation.
Weight is the biggest deterant to speed. The larger the boat and the more HP it hass, the sess the rpm and speed will be effected by this change.
Single engine outboards see the biggest hit while a 50 foot mystic with 1500 a side sees the effect less.
Brett
[email protected]
bbladesprops is offline
Old 06-26-2012 | 11:27 AM
Thanks Brett, if I had better drives I'd try the 5 blades but I already have a tweaked prop shaft and the spacers were a lot cheaper lol may not be the best all around but it's working
