Good news about crank driven sea water pumps >
Old 07-09-2012 | 10:29 PM
Default Good news about crank driven sea water pumps
Moving from pre-Alpha to Bravo required a complete re-design of my cooling system for twin SBC's. The popular favorite is the Mercruiser belt driven sea water pump that mounts on a bracket on the starboard side of the engine at about 8 o-clock. I looked at several installs with this arrangement and figured servicing that pump would be a nightmare...had to be a better way.
I have always been a fan of Marine Power and Indamar and the way they rig marine engines. I noticed that all of their rigs use a crank driven pump that mounts directly to the crank pulley. I read some old post on OSO and asked several riggers in this town about the use of this pump instead of the belt driven type that are so popular. The answer I got considered that for stock and mildly modified engines the crank driven pumps from 5 years ago and older were good choices but fell short for highly modified big block rigs. That was until about 5 years ago Johnson Pump modified their version with a larger impeller that equals or exceeds the output of the Mercruiser pumps in GPH and PSI.
So now there is no reason to prefer the Mercruiser style over the newer crank driven pumps. The new high capacity pumps are # 10-24805-01 Mod # F6B-9. This pump is offered in a kit by Michigan Motorz and Jerry's Marine that includes a torque arm bracket that bolts to the block. Servicing this thing from the front is a snap because it's right on the front of the engine....plus there is no belt to break. Not to mention these pumps retail at less than half the price of the Mercruiser pump.
This is a pic of the kit.
So I went out and bought two of these today. Suction is going to connect to the water inlet on the Bravo Transom Assembly and discharge direct to the circulating pump.
I know after reading some older OSO post that I am not the first one to do this and hope this info benefits some else facing this same question or is considering replacing their old belt driven arrangement with a simpler, easier to maintain raw water pump. If you look at the way Marine Power builds their packages you will see that all of their set ups are first class heavy duty with things like dual remote oil filters and double SS clamps on all hose connections. The fact that they use these pumps on all of their engines speaks volumes to me.
sprink58 is offline
Old 07-10-2012 | 03:00 AM
Default fixx
Volvo also use's them as well..thet kick out a bunch of water,,no belts to deal with...i have a cam driven one in my donzi...
FIXX is offline
Old 07-10-2012 | 06:48 PM
Craney's Avatar
Will they work on TRS drives??
Craney is offline
Old 07-10-2012 | 06:54 PM
I don't know of any reason why they wouldn't.
sprink58 is offline
Old 07-10-2012 | 06:56 PM
there is no reason they woudn't work with a TRS as long as there is room in front of your engine
flyinlow is offline
Old 07-10-2012 | 06:58 PM
hey sprink how much room in front of the pully do you need ?
mach1magnum is offline
Old 07-10-2012 | 07:43 PM
Depends on the crank pulley. If it's recessed...2~3" if not 4"~6".
Here's a 454 Indmar
[IMG][/IMG]
This is a 5.7 Marine Power Carbureted engine...350 Horsepower
[IMG][/IMG]
sprink58 is offline
Old 07-14-2012 | 07:52 AM
Craney's Avatar
What are the advantiges of a crank driven water pump over a belt driven water pump?
Craney is offline
Old 07-14-2012 | 08:57 AM
Easier access for maintenance fewer moving parts
sprink58 is offline
Old 07-16-2012 | 11:06 AM
C_Spray's Avatar
Diamond Member #001
Advantage:Impeller changes in under 5 minutes. Even on the water.
Here is a shot of the Jabsco 12400-model setups on my Innovation 600's. I've been using this setup for 13 years and love it.
Attached Thumbnails Good news about crank driven sea water pumps-enginesrf20080328.jpg
C_Spray is offline
