87' P22 350Mag/Alpha Prop Help
I have an '87 P22 with the 350 Mag/Alpha and it has a 21p SS Cleaver prop on it that I'm unhappy with. This prop seems to lift the transom a bit at WOT which makes it "skate" across the water. There seems to be a fine point in the trim adjustment that this prop is happy being in. My dad has suggested going to a 24p. I know nothing about props other than they push water.
With 300 horse, I wouldn't go any higher than a 23. That Alpha Outdrive is more fragile than you think and something would eventually give. If you wanna run more horses or a bigger prop, I'd suggest a 1.5 Bravo. That Alpha is a time Bomb with any real Power in front of it.
Try a 19 ballistic or 21 ballistic.
There is no way that you have the spunk to move that boat right with a 350 and a 24p prop. I ran 475 hp through my Alpha with no problems for 5 years but it had changed to 1:36 gear ration so the strain was on the engine and not the drive. I ran a 19p ballistic for general use and the 21 for speed, they get loose at 68 and above.
I run a 21p Mirage on my 350 Pachanga. I don't see how you can run a 24p on and alpha/350 combo. only other prop I've tried was a 23p 5 blade which hopped on plane like a jet ski but didn't have much top end. I'd start with the Mirage and see what you think. I've been happy with mine.
I used a 23p vengeance on mine and was very happy with the outcome. My engine was a bit more than a normal 350, but the prop was spot on, good plane time, good cruising speed and good top end. And less expensive that a lot of other props.
How will a 21p Mirage be different than a 21p Cleaver? How would the 21p Ballistic be different than either of those?
What characteristics would change going from a 21p to a 23p?
And we're usually out with another couple, so that's me, my wife, my 2 year old son and two other adults.
Kurt
