Quick help >
Quick help
Quick help
Old 07-24-2012 | 05:24 PM
Default Quick help
I have a 98 27 fever with 502 under the engin hatch hooked to the back of the seat is a bottle of what i can tell hydroalc fluid one hose off the bottom of it to a pump i would say for stearing or trim tabs it looks a little pinkish insted of red if its hydrolic oil should be red? I called my dealer and he said its common and not to worry pink would mean water i would say? boat is fairly new to me iv never had hydrolic steering what u guys think thanks for ur help.
maine27 is offline
Old 07-24-2012 | 07:51 PM
Prolly for your tabs or trim....
jmoore1225 is offline
Old 07-24-2012 | 08:12 PM
does it go to a pump on the pass side of the motor?? it sounds to me like its a power steering resivoir. does it look like the one in the left side of this pic??
88bullet is offline
Old 07-24-2012 | 08:20 PM
One hose going out bottom to belt driven pump on engine = hydraulic steering reservior. You should also see a small aluminum cylinder, usually either anodized blue or red, mounted that bulkhead that has one hose going in the top and one hose going out the bottom = hydraulic steering fluid filter (inside the aluminum cylinder).
bob_t is offline
Old 07-25-2012 | 12:33 AM
missed where he said hose out the bottom....
Old 07-25-2012 | 06:52 PM
Ya its the steering res im just qustioning the color looks like pepto bismald not quite as pink and i looked tonight and it says atf on it should i change it?
maine27 is offline
Old 07-25-2012 | 07:35 PM
flush it out... check your p/s cooler and steering rams for leaking. its pink cus transsmission fluid is red and its getting water in it. your cooler is on the return side so water pressure is probably causing water to enter your system through your cooler since the return side of your steering system has less pressure than the 20-30 psi water pressure you have.. might want to start there first
88bullet is offline
