Crower s-steel rockers   help!!! >
Old 09-13-2012 | 09:47 AM
Default Crower s-steel rockers help!!!
Anyone that has experiences bad or good with the Crower S-Steel please post your experiences as I am considering them for my engines as the T&D aluminum keep failing. Thanks in advance for the input. Rob
catman01 is offline
Old 09-13-2012 | 10:55 AM
bcfountain's Avatar
Registered User
I have had a set going on 8yrs now.no issues.good rockers but pricey.
bcfountain is offline
Old 09-13-2012 | 11:01 AM
I wanted to run the Crower stainless but they exceeded the budget. I'm running Crower aluminum rollers and they've got about 70-80 hours on them without a problem so far.
Trash is offline
Old 09-13-2012 | 03:13 PM
bcfountain, are they the shaft mount or stud mount that you are running?
catman01 is offline
Old 09-14-2012 | 06:15 AM
I have them on my BB Chevelle. They used to have almost 600#'s of pressure open wilth a solid roller. That was from '99 to '05. Now the cam is a hydraulic roller, 460#'s open.
Same ones, no issues, street car. Only one had a bad bearing, got metal in it, still rolled ok but was blue. (solid roller broke)
My small block I'm building for the boat will have them.
FWIW.
CC230 is offline
Old 09-14-2012 | 07:33 AM
bcfountain's Avatar
Registered User
Stud mount
Old 09-17-2012 | 10:45 PM
The stud mount seem to be proven. I am looking for more info on the shaft mount!
catman01 is offline
Old 09-18-2012 | 09:59 AM
I have a set on my 524 that have 150 hours on them and I have a 6000rpm rev limiter that I hit more often than I should with 425lbs open pressure. Just had them checked last year, still like new.
ThisIsLivin is offline
Old 09-18-2012 | 02:27 PM
Sorry, stud mont on the car.
CC230 is offline
