How many Qts. of oil in A 500efi >
Old 10-03-2012 | 10:01 AM
bmc
Default How many Qts. of oil in A 500efi
Does anyone know how many qts. of oil in a stock 2001 500efi
bmc is offline
Old 10-03-2012 | 10:04 AM
Seven
Pismo10 is offline
Old 10-03-2012 | 10:08 AM
bmc
I am pumping oil out the vents in the valve covers.
bmc is offline
Old 10-03-2012 | 10:18 AM
F-2 Speedy's Avatar
Sounds like to much crank case pressure, stuck PCV ?
F-2 Speedy is offline
Old 10-03-2012 | 04:46 PM
if the oil is at the full mark on the dip stick then you either bent a exhaust push rod or melted a piston...do a compression test..
FIXX is offline
