What pistons come in a 502 mag? >
Old 11-01-2012 | 08:33 PM
Default What pistons come in a 502 mag?
Like the title says. I just disassembled my 502 mag that was supposedly rebuilt 70 hours ago. The pistons look good, but they are je flat tops with one intake valve relief. For some reason I thought the 502 mag came with a small dome piston. The motor is 30 over.
cp5899 is offline
Old 11-01-2012 | 11:07 PM
Default 502 Dome
Yep,
the few 502 Mag from factory i have torn down are JE and have a small dome on them with valve relief.
Did you do a compression check before the tear down? Maybe the block & heads were decked below quench area.
Others can probaly help more.
Aaron
Our Scarab 34 is offline
Old 11-02-2012 | 12:37 AM
Yes, the factory pistons are a mini dome.
Eddie
Young Performance is offline
Old 11-02-2012 | 06:58 AM
These pistons are in great shape with no wear on the skirts at all, but I don't think the flat tops are going to help me get to my 600hp n/a goal.
Does anyone know of a replacement piston part number? Or even what size the dome is on the stock piston?
cp5899 is offline
Old 11-02-2012 | 07:11 AM
F-2 Speedy's Avatar
the JE700's I just pulled out of my 502 Mag look to be 10cc, and they are for sale with dimple rods connected
F-2 Speedy is offline
Old 11-02-2012 | 07:50 AM
What's the bore? I'm on 30 over now.
cp5899 is offline
Old 11-02-2012 | 08:14 AM
F-2 Speedy's Avatar
Std
Old 11-02-2012 | 09:51 AM
I can use the pistons you have if you want to get rid of them....need some 502 + and flat tops are fine with me with a procharger.../[email protected] thanks Rob
ezstriper is offline
Old 11-02-2012 | 10:55 AM
The stock pistons have a .050 dome with a valve relief. THey total 1 cc. JE has a small dome piston with a 10 cc dome that will get you where you need to be.
Eddie
