Which flywheel for bbc
Does anyone know the gm part number for
A flywheel for a 454 1 pc rear main, 168 tooth, for
Internal balance crank.
Seems to be a lot of confusion on this subject.
Thanks to all
Thanks to all
Don't think one was ever made for a one piece seal 454. They do have internal balanced type flywheel on a 572 crate engine. The thing in question would be if your coupler would bolt to it beings they use a 11 1/2" clutch compare to 11". #12582964 is the part number.
http://www.jrgmparts.com/GM_Performa...gm_chevy_.html
There are aluminum ones, not GM which are drilled to work with several different size clutches. Not cheap and don't if you would want an aluminum one anyway.
http://www.ebay.com/itm/McLEOD-ALUMI...-/110890974968
I have a 454 1pc seal block. mark v
I need to buy another crankshaft and decided to go with a 4.25 stroke because I already have correct rods/pistons.
I also need flywheel and HB.
I noticed that internal bal stroker cranks are much more abundant.
I figured it would be easiest to go all neutral.
Guess I was wrong?????
I just had the same deal when I stroked my GEN VI to a 489, I took my OEM factory flywheel, ground out most of the counter weights and then took it to the machine shop and for $40.00 had it nueral balanced. Done Deal. Just my 2 cents
Make sure you get a new harmonic balancer to match. Don't use your old one, it was for an externally balanced set up
