Anyone Tried Extractors? >
Old 12-10-2012 | 12:15 PM
Default Anyone Tried Extractors?
I have a set of Lightning headers and I'm thinking of adding O2 bungs and while I have them off, adding extractors. I know they don't add a lot of horsepower, but they help the rings seal better and last longer. Has anyone tried this and with what level of success?
ThisIsLivin is offline
Old 12-10-2012 | 12:59 PM
Are you talking about ''Burn Downs"?? Where the exhaust pulls a vacuum on the crankcase?
MILD THUNDER is offline
Old 12-10-2012 | 01:01 PM
1 MAIDEN AMERICA's Avatar
Why haven't the vacuum pumps been used either. I think NASCAR even uses them.
1 MAIDEN AMERICA is offline
Old 12-10-2012 | 01:34 PM
Yes I am, I've never heard of them called "Burn Downs" before. I have looked at Vacuum pumps, but they need to be rebuilt after every season. Extractors just seemed a low buck way to gain a few hp and increase engine life.
Old 12-10-2012 | 03:44 PM
You have my attention....what are "Extractors" exactly?
Gimme Fuel is offline
Old 12-10-2012 | 03:54 PM
Doesn't everything on a f%^$%^* boat?
Old 12-10-2012 | 04:21 PM
We used them on drag boats back in the day!! you weld in a port in each header that as the exhaust gases pass by the port it creates a vacumn that you can use to remove crankcase presuure, like a PCV valve but you don't reburn the fumes, it just goes out with the exhaust,
It worked real good with dry Headers
abones is offline
Old 12-10-2012 | 04:31 PM
Used them for years on drag engines , now they all use pumps .
Jeff P31 is offline
Old 12-10-2012 | 05:09 PM
http://www.cpperformance.com/p-14258...ac-system.aspx
http://www.cpperformance.com/p-13507...-breather.aspx
Old 12-10-2012 | 09:01 PM
they work fine on drag engines that only see a few seconds of WOT but when run for extended periods they can pull oil from the wrist pins and cylinder walls. NASCAR engines run pin oil drilled rods and oil squirter for the bottom of the pistons, etc, etc, so they can use them without issue. if the engine is not set up for all the additional oiling then the evacuation can cause more harm than the few HP you would gain. just my .02 cents though.
compedgemarine is offline
