oil temp
Old 12-10-2012 | 05:13 PM
Default oil temp
had a conversation with a couple buddys today about oil temp,one of them said the teague hp engines run a max of 160 deg oil temp,both of my boats run 190 to 200 deg,what do you guys run for oil temp?
mike tkach is offline
Old 12-10-2012 | 05:31 PM
Default Oil temp
Mike,
I have had 2 sets of Teagues motors. The 1st set and the current set use both coolers on the bell housing with no thermostat. Never any issues with condensation and the motors show virtually no temp on the gauges. Bob does not use thermostats with his motors. I run the cold waters of Lake Michigan.
Enough 4 Play is offline
Old 12-10-2012 | 05:42 PM
F-2 Speedy's Avatar
Mine barely pull off the peg even in hot days, thought they were broken till I saw them move one day.
F-2 Speedy is offline
Old 12-10-2012 | 05:52 PM
Even running LOTO hot summer air and water my temp gauges will barely move. Heat kills!!!!
Old 12-10-2012 | 05:56 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
190* + - Never a problem with condensation in the oil .
the deep is offline
Old 12-10-2012 | 05:58 PM
i get 180-200 most of the times...one must remember that cold oil does not lubricate well
pqjack is offline
Old 12-10-2012 | 07:46 PM
I see about 185-195 depending on lots of things, after a LONG run at WOT I may see 200-205, but I don't see that as an issue.
BBCLiberator is offline
Old 12-10-2012 | 09:04 PM
Mine run 180 cruising, 200-205 Firewalled for miles. No condensation. This is with the Merc HP Thermostatic remote filter mounts.
Before I had those thermostat units, Oil temp gauge barely ever moved. On hard runs, maybe 130-140, and took forever to get there. I would get some condensation in the breathers. However Bearings did look new after about 7 seasons on them when we tore down.
I also run the Bellhousing plate style coolers.
MILD THUNDER is offline
Old 12-10-2012 | 09:13 PM
FYI, Mercury uses a oil thermostat, on the 600, 800, 900, 1075, 1200, and new 1350.
Old 12-10-2012 | 09:29 PM
And anyone who knows anything about engines installed one, right?
I'll be for real, you are "eleventy" levels above what most guys see for power, but that temp is important, where it's measured even more important. You don't need a bazillion dollar motor to know that.
