TRS Gimbal Housing Gasket
Old 12-31-2012 | 01:01 PM
Default TRS Gimbal Housing Gasket
Anybody know whether or not to use any kind of sealer on the cork gasket? I cannot find anything about it in the Mercruiser service manual.Thanks
prboatdoc is offline
Old 12-31-2012 | 03:56 PM
Full Force's Avatar
I used a light coat of 4200 when I did my Baja, just to be safe...
Full Force is offline
Old 12-31-2012 | 08:03 PM
Must be looking in the wrong manual. Manual says use bellows adhesive ONLY on the housing side to retain. Do not use other than this.
Check back on your first post you made earlier in the Drives and Lower Units section.
http://www.offshoreonly.com/forums/d...ng-gasket.html
picklenjim is offline
