Composite Dist. Gear >
Old 01-02-2013 | 06:29 PM
Default Composite Dist. Gear
Anyone running a composite distributor gear?
The Get Away is offline
Old 01-02-2013 | 07:46 PM
i run them in my engines .tall decks and have had no issues they are expensive for plastic
smokin' gun is offline
Old 01-02-2013 | 08:09 PM
What style cams are you running?
Old 01-02-2013 | 08:15 PM
comp cams camshafts ground on crane cores .dist gears are comp cams also .i changed them from the bronze to the composite
Old 01-02-2013 | 08:30 PM
Sorry I should have been more specific about the style gear on the cam. I am trying to figure out why I am going through bronze distributor gears about every 20-30 hours of run time. I'm 99% sure that the cams are billet, and don't have the pressed on cast gear.
