Honda gen question
I see a lot of guys running these guys...http://powerequipment.honda.com/gene...models/eu2000i
They are amazingly quiet and a great choice, but my question is how do you rig them? Are you routing the exhaust outside or just relying on blower fans? or???
I ran a number of nights with it strapped to the swim platform with the bow anchored so the wind would help carry exhaust away....a local guy had his plumbed to run IN the engine compartment with hi-temp hose for exhaust and a fuel line T off the main supply line to the engines. He'd leave the hatch cracked and blower fan running all night when it was running......I don't think I would have run it like that but it actually looked OK the way it was setup.
X2
I use a bungee.
I run a batt charger and it keeps all this running
Nav scree/ Video at night/ Radar watchman mode (big lakes)
9" Screen in cabin
9" Screen in midcabin
20 LED lights
Stereo
12V chargers (phones laptops/ wifi)
+ I run a 12V low power AC unit in the cabin at night to sleep and even though its "low" power it will flatten a Pc 2150 in 3 hours.
Ive never had any issues, but I have a detector.
Uncle Dave
I use a bungee.
9" Screen in cabin
20 LED lights
Stereo
Uncle Dave
X2
I use a bungee.
9" Screen in cabin
20 LED lights
Stereo
Uncle Dave
I use a bungee.
9" Screen in cabin
20 LED lights
Stereo
Uncle Dave
Too bad these don't have an electric start option.
My boat does not have an "inverter."
Its a straight up 12V system connecting to pc2150's and a perko switch.
All the stuff onboard is 12V (Ill plug an inverter from 12 to 120 for laptop AC inside the cabin. )
My motorhome has an inverter the inverts 12V to 110 using the 4 house batteries. I use the 2K to run a charger to the house bank to control the load on long camping trips. This way I can idle the genny the whole time.
The honda generator is an "inverter" which means it can vary the RPM to suits the load placed upon up to 2000 W for 20 minutes then 1600 sustained.
Battery charger, I have half a dozen of them the little schumacher is great , and I have couple other brands I like but their name escapes me. Ill go look. Typically 20 AMPs is the highest Ill go.
I use the 2K - great little machine. The 1K is just a bit weak for my needs. Ive got 2 of them a camo unit and a "companion"
Got a zillion hours on the camo unit & has run literally weeks flat out powering the wife units dog grooming van while the big onan was out for service.
Yeah electric would be nice, but they are easy to start and the cord lasts about 5 years of light use and three of heavy before you have to replace them - which is a bitc#.
If I had to buy all over again today - I'd buy the yamaha.
Ive done a couple of timing belts now on the camo unit and the Yamaha uses a chain- nicer IMHO
I also like the ability to drain the float bowl with a fuel shut off - a very nice feature for a seldom used genny, you will be fighting bad gas forever if you let them sit without draining the float bowls.
Uncle Dave
X-2 on the carbon monoxide sensor!! We almost lost two boys at a rodeo one year and they had the generator in back about 10 feet from the trailer but the breeze was just right and sent the exhaust into the trailer and they had to be carried out almost comatose, both were revived and rodeoed that day but it was scary as you don't know it is happening and just go into a deep sleep.
