4.500 je piston
Old 03-11-2013 | 05:06 PM
Default 4.500 je piston
I need one 4.500 flat top piston with the 3cc valve relief (stock stroke and rod length). I have 7 good ones but one with a hole in the top from an intake gasket that was sucked in or not installed right. My pistons have two 1/16 ring grooves and the oil ring is 3/16.
cp5899 is offline
Old 03-11-2013 | 06:51 PM
I have small dome ones one set you can mill them off $500 for the set
kidapache is offline
Old 03-11-2013 | 09:18 PM
The ones I have are good so I just want to find one to replace the bad one.
cp5899 is offline
Old 03-12-2013 | 07:32 PM
Still need one piston if anyone has one.
TTT
cp5899 is offline
Old 03-12-2013 | 07:45 PM
you can buy just one from j&e.
mike tkach is offline
Old 03-12-2013 | 07:49 PM
I looked into that, but figured I would check here before buying new.
cp5899 is offline
Old 03-16-2013 | 10:34 AM
Still need a piston if anyone has one.
TTT
cp5899 is offline
Old 03-16-2013 | 06:53 PM
TomFTM's Avatar
What is the rod length . I believe I have 6 4.50 JE for 6.385 rod .
TomFTM is offline
Old 03-16-2013 | 07:02 PM
Stock rod length.
cp5899 is offline
Old 03-18-2013 | 10:24 PM
I have a full set with VERY LOW hours for $500
adrenalinejunkey is offline
