Rod bolt stretch specs needed
Does anyone have the rod bolt stretch spec for the ARP bolts used with the Eagle I-beam rods? These are the cap-screw bolts. I found torque values on Eagle's site for 63 ft lbs, but want to use stretch instead.
Thanks!
Thanks!
Wait a minute; do you have a I beam SIR rod, or a H beam?
I have read several threads that indicated that it took considerably higher torque to get that stretch value, even with the ARP lube. I torqued to 63 a couple of times, and followed up with a stretch gauge to .0055, and it sure felt like I was pulling more torque, although I don't have a torque extender to put a torque wrench on it while using the stretch gauge.
It will require more torque, even with the ARP lube to get the stretch. I would take it to .006 & stop.
