GM EXPERTS need some 5.3 LC9 engine interchange info >
Old 03-29-2013 | 09:20 AM
Default GM EXPERTS need some 5.3 LC9 engine interchange info
Hey guys,
I'm working on a 2008 Suburban for a good customer of mine, and it has a blown 5.3. The engine lost oil pressure and is toast. I usually don't mess with this kind of stuff, but he is a really good Porsche and Ferrari customer of mine so I want to help him out.
Does anyone know what engines will interchange? I'd like to find a nice low mile complete drop in so I don't have to switch a ton of parts over.
It's a 2008 1500 LTZ 4x4. It has the aluminum LC9, does anyone know if one of these ebay units will work? They list 2010-up on the adds, but being complete with ecu can I swap it all?
Thanks!
Will post vin and airbox code in pics in next post...
RT930turbo is offline
Old 03-29-2013 | 09:21 AM
Here is one I'm considering.
http://www.ebay.com/itm/5-3-LITER-VO...594ea4&vxp=mtr
Old 03-29-2013 | 09:23 AM
Pics
Attached Thumbnails GM EXPERTS need some 5.3 LC9 engine interchange info-image.jpg
Old 03-29-2013 | 09:24 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
A good friend of mine and OSO member owns Factory Engine Exchange. I'll PM you his number.
Sydwayz is offline
Old 03-29-2013 | 06:18 PM
Default fixx
have pitch a ***** with gm,,those 5.3 engines have a bad habbit of eating oil and gm is aware of it...if you ***** enough they may cover it under a warranty...as for exchange to new to figure out..
FIXX is offline
Old 03-29-2013 | 06:22 PM
Already tried that option and unfortunately they aren't budging...
Old 03-29-2013 | 06:24 PM
Default fixx
How many miles are on it? and did you mention how many complaints their are about oil consumption on the internet? they offewred to rebuild my friends moms and it was at 110,000
FIXX is offline
Old 03-29-2013 | 06:32 PM
powertrain is good til 4/17/2013 or 100k!! prob over on milage tho
88bullet is offline
Old 03-29-2013 | 07:15 PM
115k, purchased new, etc. had a cylinder head replaced at 97k, and he asked them to do both under warranty. They did not, and this apparently is the same issue on the other side. Maddening to say the least!
Still can't find a definitive answer but im 99% sure the 2010 LC9 will work,
Old 03-29-2013 | 08:04 PM
i work at a gm dealership.... call gm customer service and blow your stack. you might have to pay a couple hundred for a deductible but they should cover it. go above the heads of the dealership. start a claim with gm stating your case of your motor repair history and you have had problems in the past. then Gm will call the dealership and they should good will it
88bullet is offline
