fuel sending unit with duel return lines? >
Old 03-30-2013 | 09:05 AM
whiskeyhangover's Avatar
Default fuel sending unit with duel return lines?
Does anyone make one?
whiskeyhangover is offline
Old 03-30-2013 | 02:48 PM
mcollinstn's Avatar
What are you even asking?
I don't mean to sound abrupt but I don't understand your question.
A fuel sending unit has a ground lug and an output terminal (for variable resitance thru the ground) for sensing the fuel level.
Why would it have one return line, much less dual ones?
MC
mcollinstn is offline
Old 03-30-2013 | 03:50 PM
Some diesel and fuel injection engines use a return line back to the tank, going through the fuel sending unit may help make some installations a bit easier.
I haven't seen a marine duel return line, just a single like this,
http://www.amazon.com/Moeller-Marine.../dp/B000MTI15U
lakematdude is offline
Old 03-31-2013 | 06:50 AM
to help with the massive vapor lock problem we've been having
Everyone has been telling me to make a return back to the tank and to keep from
Drilling the tank someone told me to find a fuel sending unit with a return line.
I didn't kniw if they made one with duel return lines or not but I bet I could drill an extra one with a few fittings... .
Thanks lakematdude! I will order one
Old 03-31-2013 | 07:57 AM
CP has a fitting where you can cut your fill hose to your tank and install your return lines.
fbc25el is offline
