Engine upgrade in process. ADVICE
At the end of season last year i spun a bearing on the BLOCK, catastrophic failure. I did not realize the extent of the problem until my engine builder pointed it out. After give me some options I decided to upgrade. 565ci carberated, dart irion eagle heads ported and polished to 390cc, JE pistons, MSD Ignition, Dominator 1050CFM carb, ect....
Here is my dilemma. When i removed the engine I really did not take measurements or photos that would be helpful to me making the my next purchases. I need to know the following: Carb pad height, need max height intake i can use
Maximum height i can go with lightening headers and capitons call exhaust
Oil pan type, I've seen two styles and max size
Am i able to do away with my water pump and install just a cross over. Would also like to know the pros and cons on crossover vs water pump.
Basically i need dementions of engine compartment or to know what i can use.
1994 21'Baja Twilight Cruiser
Thanks in Advance!
Thanks in Advance!
Just about had all the info for ya's. Existing engine was 7.4L454 330hp. As i said in the above photos i have aren't the best but here they are. Well maybe not, seems i can't upload pics. here is my email if you like to send me yours and i can shoot over some pics or if i'm missing something to upload photos. Boat is still in storage and dont have any with engine compartment empty. I could prob get some.
Give me a few days Randy. I'm going to make arrangements to get it out of storage this week, get some other photos and become a paying member here. I'll keep you posted.
Photos you sent based off photos i have it looks pretty close. What about the other questions i had?
Usually in a marine application you don't necessarily want to have large runner volumes. We usually don't spin our engine above 6000RPM. So we try to take advantage of the smaller volume runners and get the best flow with the least cross sectional area. This will in turn have a higher port velocity creating low end torque. Boats are all about flat torque curves and building peak power in a limited RPM. Do you have the cam specs?
