Could you build a Carbon Fiber Trailer?
Mod Squad Enforcer
Given that some of our boating brothers believe in over-the-top type things, why hasn't anyone built a CF or composite trailer?
I realize that the suspension etc might need to remain aluminum or steel, but couldn't the frame, bunk rails and winch tower be done? Wouldn't it prolong life in saltwater areas and also provide a much lighter platform to tow with? Would you be able to make it so that the suspension/wheel system was modular and could be swapped out for rebuild or maintenance?
I'm a Realtor, not an engineer, so I just wondered why it hadn't been done.
Flame away....
Flame away....
yes you can, but the cost would be horrible (maybe not for some). leaf springs for certain applications are carbon and have been for some time. the union of carbon and metal is also possible as well. so axle beams and wheel hubs could be joined. one problem with carbon would be direct sunlight.....it doesnt fare well in it and salt water combined with the sun would have another effect on it.
However, you could wrap carbon over thin walled aluminum (rectangular tubing) for frame rails. it could then be drilled with less chance of fraying or fracture.
It could be done, however any damage to the surface coating would have to repaired immediately. So scraping a ramp could be catastrophic. However, anyone with enough money to build a cf trailer is probably craning their boat into the water.
Great idea.
I'm thinking some of my Australian water ski racing friends have used it for parts of their trailers but not sure. Thinking I've seen it in their fenders anyhow.
They too go way over the top on their rigs and that would fit right in.
Years ago I worked on a jeep commando show vehicle that had a carbon frame sort of.
The rails were made of carbon wrapped honeycomb, from I think aluminum. Pretty wild, had a fuel cell in it. People loved it at CES that year.
Mod Squad Enforcer
As for light sensitivity etc. I would think just painting it would fix that. After all, it's about weight savings and longer life in my estimation.
Carbon fiber is preferred in strength to weight ratio for building airplanes, but at same time, deflection under the same weight matters a lot. Aluminum will bend at its deflection limit and carbon will shatter.
Materials and labor would bankrupt you compared to steel or aluminum welded trailers.
