???Can 250 chillers be modified to work with 177??? >
Old 04-20-2013 | 10:29 PM
Default ???Can 250 chillers be modified to work with 177???
I can't seem to find any used chillers for my 177 B&M's...... Does anyone know if a superchiller for a 250 can be modified to work with 177 intake and supercharger?? What about making adapter sets for intakes and blowers?
adrenalinejunkey is offline
Old 04-21-2013 | 06:34 AM
Audiofn's Avatar
Charter Member #232
Wouldn't you be better off going with a larger blower?
Do you want me to move this to the tech area?
Put your best foot forward!
Audiofn is offline
Old 04-21-2013 | 08:03 AM
ya... seems like a waste of $$$ put that extra mod money into the 250s that are supposed to go on them and smile with the power gain
adk61 is offline
Old 04-21-2013 | 08:07 AM
I would be better off I'm sure but I've got twins and that gets spendy, plus I'm spending tons of $$$ on other things. Another reason I ask is I found 2 250 chillers real cheap and I was a machinist for 18 years and wasn't sure if anyone had tried this. If I had a 250 chiller in front of me or all the demensions I could figure it out myself.
Good idea on moving it if you could. Thanks!!!!
Old 04-21-2013 | 08:24 AM
Thank adk61 also for your input...... I was afraid that might be the answer. As stated above, I found a set of 250 chillers for $300 and figured I'd see if it were possible. The motors didn't have chillers previously but I wanted to throw more boost at them.......
Old 04-21-2013 | 10:13 AM
If you have a bridgeport and a big chunk of aluminum anythings possible,,,, but how much is that big chunk of aluminum??
phragle is offline
Old 04-21-2013 | 10:28 AM
My thoughts exactly!!!!
Old 04-21-2013 | 10:59 AM
The 250 blower has a much longer (front to rear) case. The bolt pattern, intake openings, etc, is much different than the 177.
Attached Thumbnails ???Can 250 chillers be modified to work with 177???-dsc02268.jpg   ???Can 250 chillers be modified to work with 177???-dsc01141.jpg   ???Can 250 chillers be modified to work with 177???-006-3.jpg
MILD THUNDER is offline
Old 04-21-2013 | 02:40 PM
I see...... Yes definitely way too much fabrication needed. Thanks guys!!!!
