need adjustable FPR on 496ho raylar103kit ?
I would like to know if i need a adjustable fuel pressure regulator to increase the psi in fuel system...?
Ive hearded about drilling a bigger hole in the throtle body to fix the idle issue...
If it is running, leave it alone, dont start fooling with 2 regulators. The only way to know is put an A/F bung and get some numbers.... Dont start running all kinds of irradic pressures. You can take the rail off, cut the current regulator off (little round black thing on the rail) put an AN fitting and get an Aeromotive (or similar) but it will create irradic pressures at other RPM levels.
I sent you a link PM to an Aeromotive 496 setup...
