38 cigarette trim
Old 06-10-2013 | 08:33 PM
Default 38 cigarette trim
Hello
Just started getting the 38 Cigarette out on the water. I am having trouble getting it to plane out as fast as my 32 Fountain would. It has 525 motors, 32 pitch boavo one four blade props,approx. 1/2 fuel load,and four average adults. I have to really feather the throttle or the props break loose. What am I doing wrong or does it just take a little longer for it to plane out?? Any advice??
David H is offline
Old 06-10-2013 | 08:35 PM
TeamSaris's Avatar
Driver-441
Racer
525s and 32s? Seems like a lot of prop for a large boat. What gears? Always tuck it all the way in when getting on plane
TeamSaris is offline
Old 06-10-2013 | 09:22 PM
J-Bonz's Avatar
Don't forget throwing the tabs down to. 38 top gun, I will guess you have either bravos or TRS's. it's a heavy boat. Best to take it easy getting on plane. As for props, I am not sure
J-Bonz is offline
Old 06-10-2013 | 09:43 PM
johnnyboatman's Avatar
2 totally diff boats, the fountain is smaller and lighter, the cig is heavier, give it a few outings and you will get the hang of it.
johnnyboatman is offline
What type of drives Sportmasters? I had the same boat for three years same power and Sportmaster drives the boat hates getting on plane but this is what I did. First tuck the drives all the way in and set tabs a little lower than neutral setting the tabs down too far lifts the stern up which then breaks the props free. I always made sure I had a clear path in front of me. Keep trying different tab settings it will get up on plane. Good luck Joe
Joetool is offline
Old 06-10-2013 | 10:30 PM
I always found that with these high X sportmaster boats that slightly turning while planning helped out quite a bit. Try a big diameter prop 35 Fountain with -2's. That will embarrass you at the bouys!
TxHawk is offline
Old 06-10-2013 | 10:55 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
What year is this 38TG in question?
Twin step or straight bottom?
525SCs or 525EFIs?
Sydwayz is offline
Old 06-11-2013 | 09:36 AM
4195's Avatar
Can You Hear Me Now??
Originally Posted by TxHawk
I Try a big diameter prop 35 Fountain with -2's. That will embarrass you at the bouys!
What does this mean?
4195 is offline
Old 06-11-2013 | 09:44 AM
I think he means in the turns.
Mastercraft240 is offline
Old 06-11-2013 | 09:57 AM
I'm guessing t/s 525 efi's my buddy has an 03 and 32 bravo 1's is what he runs. Its and -2 lowers. Sucks getting on plane. Drop the tabs, tuck the drives and feed it throttle seems to work best for him. Right wrong or indifferent it works
Unlimited jd is offline
