silent choice question?
You CAN NOT use this under any RPM. I believe that they recommend a max of 2000 RPM. I have Captain's Call, and they actually open automatically if the RPM gets too high (yes.....I forgot to turn them off).
Chris, that was a free shot, take it
I will tell you what happens to a blower motor that is run with the silent choice on.......Melted pistons!!!!!!!!!!!!!!!!
This was a result in a system not put back together properly. Mine is run on air pressure and there was a leak. The mechanic that test drove the boat did not realize they closed till it was too late.
The result..........Total rebuild, balance and blueprinted and head work. Now they run better than ever.
