Strering Problem >
Strering Problem
Strering Problem
Old 07-29-2013 | 07:04 PM
Default Strering Problem
My sister bought an 1993 Mach1 and it takes both hands to turn at any speeds. Thinking cable bad? ( fluid level good, belt tight)
boatguy94 is offline
Old 07-29-2013 | 08:14 PM
pull the cable from the actuator and check..... Is it the same stiffness as when its not running??
phragle is offline
Old 07-30-2013 | 12:14 PM
If its not the cable and the pump is functioning, its the actuator valve. The valve would be my guess unless that cable is really far gone.
MEANGREEN231 is offline
