lifting
Old 08-04-2002 | 09:40 AM
velocity260's Avatar
Default lifting
I have a velocity260 apporx: 5000lbs, I want to lift it off the trailer to do some work. Can you lift it with the bow ring and stern rings? I have done this before lifting smaller boats without a
problem. If not I have a lifting frame with slings if the rings are not strong enough.
velocity260 is offline
Old 08-06-2002 | 02:56 PM
I've lifted my 26' T'bred by using jacks, blocks of wood, and cinderblocks. My neighbors thought I was nuts. There are a few threads on OSO about this, everybody with differing opinions of course. Took my less than an hour to get the trailer out from under it.
John
JohnJan is offline
Old 08-06-2002 | 05:47 PM
Revelocity's Avatar
I would definitely NOT lift it by the rear rings which are far too small to support the boat/engine weight. Take a look at the special purpose lifting rings on a F1 boat and you'll see what I mean.
Marine screw jacks, cinder blocks, wood blocks and/or HD hydraulic floor jacks are the best way short of having a travel lift sling arrangement.
Revelocity is offline
Old 08-06-2002 | 08:49 PM
I kind of did both used the rings to get the slings under then used the slings to lift the boat.
Old 08-07-2002 | 07:36 AM
velocitoy's Avatar
Question
HEY 260, They ARE called "LIFTING RINGS"!!! It sounds like you were being better safe than sorry....(SMART)!!! I don't think it's a problem on the under 30' boats tho.....
velocitoy is offline
Old 08-07-2002 | 05:03 PM
Revelocity's Avatar
Glad it worked out for you. I was surprized but the guys at my marina can slide the slings between my 320 hull and the trailer bunks with no trouble what so ever using 2 guys! It should be easier for a lighter boat.
Old 08-07-2002 | 08:40 PM
probally could of pulled them it was tight though. I figured why fight it though. I used one of our trucks that delivers concrete block, same one I use for lifting Slow boats"sailboats" for the winter. That is what the sling and frame are meant for. the truck at close range it can lift 10,000lb's. 30ft out it can lift 4,000lbs.
offthefront
5
05-17-2006 08:01 PM
nordic95
5
04-12-2006 07:27 PM
tpenfield
05-01-2005 09:16 PM
lukiepal
6
12-03-2004 07:39 PM
DRTOBE
5
04-08-2003 12:22 PM
