No fuel pump provision on motor >
Old 08-16-2013 | 09:26 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Default No fuel pump provision on motor
Have a motor with no fuel pump boss.Want to use a merc elec pump that I have # 861155-2 .Problem is I don't remember if this came off of a carbed or injection motor.I want to use it on a carbed motor. Does anyone know or have any input.Both the in and out ports are threaded, injection pumps I think only have one side threaded but not sure.JOHN SR
Fenderjack is offline
Old 08-16-2013 | 12:08 PM
Rookie's Avatar
http://www.boatfix.com/merc/bullet/00/00_05.PDF
Rookie is offline
Old 08-16-2013 | 12:59 PM
No Merc carbed engines used electric pumps.
Griff is offline
Old 08-16-2013 | 01:45 PM
Fenderjack's Avatar
They used them my neighbor has one.it's a 4.3 with a 2barrell JOHN SR
Old 08-16-2013 | 02:09 PM
They never did it on a b/b . Always used the sea pump fuel pump combo
If its a b/b why not do it that way
smokin' gun is offline
Old 08-16-2013 | 02:11 PM
Fenderjack's Avatar
Its a small block.Thanks someone rebuilt the motor and put a cam in with no lobe to run the fuel pump.LOLJOHN SR
Old 08-16-2013 | 04:19 PM
GRIFF .....? My buddies 24 Outlaw w/ a 454 Carb has a electric fuel pump ?????????????????? Is it not a Merc motor ????
1stoutlaw is offline
Old 08-16-2013 | 06:52 PM
oh yes they did! ..the 220 hp 4.3 v6 vortec did..
FIXX is offline
Old 08-16-2013 | 07:08 PM
My boat has a 515 BBC with a Aeromotive pump. You need to see what the Merc pump pressure is before trying to use it with a carb.
7 psi Max, or to 14 PSI with a fuel return line to the tank.
Ditch the Merc and get a 7 PSI Aeromotive pump.
toyo321 is offline
Old 08-17-2013 | 02:09 PM
I guess I should have said BBC Mercs. I know nothing about V6's or SBC's.
Most likely it was switched from the OEM mechanical fuel pump on the sea pump to an aftermarket electric pump.
Griff is offline
