stainless marine sbc maifold clearance
does anyone know if sbc stainless marine manifolds will clear tall valve covers without a spacer?ordered some today and forgot to ask.the covers are gmpp cast tall covers.thx in advance.
They will NOT clear the normal squared edge ones. I used them on a vortec stroker motor I built for my previous boat. You can also get a steel spacer for the manifolds and use tall fabricated ones that have slight angle to the edges. Spectra performance sells a decent set of fabbed vented bolt ones that I used.
No they will not clear but you can use these with a thicker gasket.Our 383's in the old 272 Formula it's what we used.
Registered User
As said above, they will NOT fit, I tried thicker gaskets didnt work, ordered a set of 1" spacer thought that might work it only made the problem worse. FYI if you need a set of spacers I have a brand new set & two brand new sets of super nice tall square aluminum 3/8 flange valve covers haha......
