IMP 310 Rebuild/modification >
Old 10-28-2013 | 10:00 AM
Default IMP 310 Rebuild/modification
I thought that I would share a little project of mine (That became bigger) a rebuild/modification of an old IMP310.
The boat is a -89 310-Eleganza with busted engines which I bought from a customer.
[ATTACH=CONFIG]511090[/ATTACH][ATTACH=CONFIG]511091[/ATTACH][ATTACH=CONFIG]511092[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-1.jpg   IMP 310 Rebuild/modification-2.jpg   IMP 310 Rebuild/modification-3.jpg
ragman is offline
Old 10-28-2013 | 10:41 AM
Almost all of the mess caused by the broken engines cleaned up here.
[ATTACH=CONFIG]511098[/ATTACH][ATTACH=CONFIG]511099[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-5.jpg   IMP 310 Rebuild/modification-6.jpg
ragman is offline
Old 10-28-2013 | 10:46 AM
From the beginning I was only going to change the engines and fix some of the interior.
But one thing led to another and later on during the project everything went a little out of hands.
Made som templates for new instrumentation.
[ATTACH=CONFIG]511100[/ATTACH]
The first version of the dash.
[ATTACH=CONFIG]511101[/ATTACH][ATTACH=CONFIG]511102[/ATTACH][ATTACH=CONFIG]511103[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-7.jpg   IMP 310 Rebuild/modification-7_1.jpg   IMP 310 Rebuild/modification-7_2.jpg
IMP 310 Rebuild/modification-7_3.jpg
ragman is offline
Old 10-28-2013 | 11:08 AM
Here we have laminated the stern to make room for Bravo transom instead of the previous TRS.
[ATTACH=CONFIG]511104[/ATTACH]
We also removed the skyport and laminated with Divinycell.
[ATTACH=CONFIG]511105[/ATTACH]
Mounted some scoops from Eddie Marine
[ATTACH=CONFIG]511106[/ATTACH]
[ATTACH=CONFIG]511107[/ATTACH]
Removed all of the bolts from the inside of the windscreen and laminated it instead
[ATTACH=CONFIG]511108[/ATTACH]
Made some adjustments to make the engine hatch fit better
[ATTACH=CONFIG]511109[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-8.jpg   IMP 310 Rebuild/modification-9.jpg   IMP 310 Rebuild/modification-12.jpg
IMP 310 Rebuild/modification-13.jpg   IMP 310 Rebuild/modification-14.jpg   IMP 310 Rebuild/modification-15.jpg
ragman is offline
Old 10-28-2013 | 11:16 AM
Here are some early build pics of the new bolsters being built by Boat and Car fashion a local company in Sweden.
[ATTACH=CONFIG]511114[/ATTACH] [ATTACH=CONFIG]511115[/ATTACH] [ATTACH=CONFIG]511116[/ATTACH]
We also laminated new headrests for the backseat
[ATTACH=CONFIG]511117[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-16.jpg   IMP 310 Rebuild/modification-16_1.jpg   IMP 310 Rebuild/modification-16_2.jpg
IMP 310 Rebuild/modification-16_3.jpg
ragman is offline
Old 10-28-2013 | 11:22 AM
Here the boat has been moved to our painting facilties
[ATTACH=CONFIG]511118[/ATTACH] [ATTACH=CONFIG]511119[/ATTACH]
I couldn’t decide what rub rail to choose so I decided to make the boat seamless instead.
[ATTACH=CONFIG]511120[/ATTACH] [ATTACH=CONFIG]511121[/ATTACH]
[ATTACH=CONFIG]511122[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-17.jpg   IMP 310 Rebuild/modification-18.jpg   IMP 310 Rebuild/modification-19.jpg
IMP 310 Rebuild/modification-20.jpg   IMP 310 Rebuild/modification-21.jpg
ragman is offline
Old 10-28-2013 | 11:27 AM
Great looking boat. Nice job. Keep the pics coming. I owned an IMP and had a ball with it.
smckie is offline
Old 10-28-2013 | 11:29 AM
Some pictures from different modifications made just before we started with the paintjob
[ATTACH=CONFIG]511123[/ATTACH] [ATTACH=CONFIG]511124[/ATTACH]
[ATTACH=CONFIG]511125[/ATTACH] [ATTACH=CONFIG]511126[/ATTACH]
[ATTACH=CONFIG]511127[/ATTACH] [ATTACH=CONFIG]511128[/ATTACH]
[ATTACH=CONFIG]511129[/ATTACH] [ATTACH=CONFIG]511130[/ATTACH]
[ATTACH=CONFIG]511131[/ATTACH] [ATTACH=CONFIG]511132[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-22.jpg   IMP 310 Rebuild/modification-23.jpg   IMP 310 Rebuild/modification-24.jpg
IMP 310 Rebuild/modification-25.jpg   IMP 310 Rebuild/modification-27.jpg   IMP 310 Rebuild/modification-28.jpg
IMP 310 Rebuild/modification-29.jpg   IMP 310 Rebuild/modification-30.jpg   IMP 310 Rebuild/modification-30_1.jpg
IMP 310 Rebuild/modification-30_2.jpg
ragman is offline
Old 10-28-2013 | 11:38 AM
A few pics of the paint job
[ATTACH=CONFIG]511133[/ATTACH] [ATTACH=CONFIG]511134[/ATTACH]
[ATTACH=CONFIG]511135[/ATTACH] [ATTACH=CONFIG]511136[/ATTACH]
Attached Thumbnails IMP 310 Rebuild/modification-31.jpg   IMP 310 Rebuild/modification-31_1.jpg   IMP 310 Rebuild/modification-31_2.jpg
IMP 310 Rebuild/modification-31_3.jpg
ragman is offline
Old 10-28-2013 | 11:39 AM
Thanks for the nice comments More pics to come
ragman is offline
