Best cables made for tight radius trim and throttle? >
Old 11-22-2013 | 02:50 PM
2 Trick Rick's Avatar
Racer
Question Best cables made for tight radius trim and throttle?
I need longer cables anyways and seeing as I have a couple tight bends inside the canopy might as well get something that will make the bends with as little drag as possible. What would you guys recommend?
2 Trick Rick is offline
Old 11-22-2013 | 03:28 PM
his screen name here in OSO is KEVLARKAT32. He's been using teflon coated cables:
read on :
http://www.offshoreonly.com/forums/s...ml#post3564421
noli is offline
Old 11-22-2013 | 03:33 PM
check out his hatches and hidden hinges
http://www.offshoreonly.com/forums/s...ter-hatch.html
NACA Scoops for Optis:
http://www.offshoreonly.com/forums/s...i-engines.html
Custom controls and screw-less dash
http://www.offshoreonly.com/forums/s...ation-o-b.html
Custom fuel tanks
http://www.offshoreonly.com/forums/s...ank-refit.html
noli is offline
