Reversion, Reversion Reversion >
Old 12-15-2013 | 05:43 PM
It seems to hit many people, is it an issue with through prop exhaust and stock manifolds also? is there anything I can do to prevent it while the motor is still out? Maybe new flappers?
stimleck is offline
Old 12-15-2013 | 05:47 PM
can turbulators be retrofitted?
stimleck is offline
Old 12-15-2013 | 05:53 PM
Stock exhaust will be fine if your running a stock engine. If cam has been upgraded you may need to change exhaust depending on the specs.
Through prop will rob performance.
Baja226sport is offline
Old 12-15-2013 | 06:05 PM
Here is a pic off some ss piping I used instead of exhaust hose and got reversion first time out,Im not using them again.[ATTACH=CONFIG]514310[/ATTACH]
nautimarine is offline
Old 12-15-2013 | 06:50 PM
jeff32's Avatar
ss or rubber does not make a difference IMO. flappers, and maybe even on the outside , might help, slowing down slowly not to take the hit from the wave behind... couple different things can help!
jeff32 is offline
Old 12-15-2013 | 07:39 PM
those pipes in the picture are level then drop down with no internal flappers then came off plane to fast and steam cleaned some exhaust ports
Old 12-15-2013 | 08:57 PM
I backed a non-thru hull into launch too quick and caused it also!! On thru hull: If no internal flappers, get external and i always give her a little throttle when she is about to sit in water coming off plane.
nailit is offline
Old 12-15-2013 | 09:13 PM
You wont have to worry about reversion too long if you keep that squeeze bulb for your fuel in the engine compartment.
Katanna is offline
Old 12-15-2013 | 09:30 PM
Thats funny,I just put the engine in the boat and used the bulb to fill carb,no longer in boat,I like people that pay attention to detail, good eye
Old 12-23-2013 | 08:32 PM
Reversion
longtravel is offline
